fan and overheating
  • fan and overheating
    my truck overheats under load, i have heard the viscous fan may need oil put in it is this true if so how.it may be too late anyway as its been in the red twice.
    Do a search on Viscous Fan....you should get all the info you need... basically you take fan assembly off , split it ,clean refill and refit. I locked mine up with silicone sealer, Vince and a few others locked theirs with bolts
      Some bed time reading for those long winter nights
      http://www.hiluxsurf.co.uk/forums/se...d=327804&pp=25
      Another member of the 'A' team
        under load?
        do you mean normal accellerating, or towing up a hill??
        you might need to get yourself an oil cooler for the transmission fluid.
        (grrrr!!... I.E7's nicked my spell checker too!!)
          What servicing have you already done to the cooling system? Are you
          losing any coolant?
