Hi
Any one technical know If It's likely(or possible) to crack a head between water jacket and oil gallery?
I have got some oily sh**e in my expansion bottle, had some over 8 months ago cleaned it out but now It's back!
Question is,is It engine oil?
Or is It ATF fluid from a leaky cooler in the Rad?
Performance is good, no light or white smoke and had a combustion gas test and It was negative! As Iv'e had the rad out sooo many times for mods and repairs(It's leaking again) i wondered if the cooler was damaged and leaking into the coolant!
I'm gonna bypass the inbuilt rad cooler when i get an ally one made as i already have 2x tranny coolers(air to oil) to see if this helps!!
Neil
Neil
