Long legs and gear sticks
  • Long legs and gear sticks
    Allo ,
    OK so I'm a long legged geeza,( I blame me mum) ? when Im in fifth gear my knee is up against the stick and seat right back. So I thought if I took the stick out and applied some heat then bent it forwards and inch or two ?,,,,,,,,,,mmmmm
    anyone done this?
    While on the gearstick thing my Hi/Low stick rattles on tick over , any suggestions on how to stop it . drive's me nuts erm well not me nuts exactly but crazy. what d'ya reckon
    Hi maybe your tick-over is to low it should be around 750rpm to 800rpm.
    Live Life To The Full
      reply
      tick over is fine thanks , I wish it had been that easy........ Ho Hum
        Mine rattles as well. I've never bothered doing anything about it but as it seems the main rattle is from the large centre button I'd thing an elastic band round the knob ought to cure the noise.
        Mike G
          I think all the 4wd buttons rattle from what i've heard , best and cheapest cure is to shove a small removable wedge between the button and the stick ie matchstick or piece of fag packet folded up !
            Mine doesn't, I reckon it's just you 3 litre boys!
              I KNEW THERE WAS SOMET BETTER ON THE 2.4'S I JUST COULDNT FIND IT!!
              CHEERS JOHN................
                Two more things they haven't got, a green turbo light, and a beeeeeeeeep if the ignition is left on without starting engine.
                  Ahhh. Poor little things!!!
                  It just does, OK?
                    YEAH YOU LOT SHOULD OF BOUGHT A 2.4 AND YOU GET A FREE BEEEEEEP... ERRRRM WHY AM I SHOUTING!! thats better...
                      i got the beep on mine with keys in the ignition but i aint got a turbo light.
                        Har Har, 2.4 wannabe.
                          no no no 2.4 has been
