i have a 3rd gen with 60000 kms on the clock cant fault it at all exept for one thing when i brake i get a slight shuddering through the brake pedal and the steering wheel any ideas
Shudder under braking
sounds like front disks are slightly warped or, if new ones have been fitted recently, a bit of muck etc. has got between the disk & the hub causing a bit of run out.
If the disks are new, you could try removing them, cleaning the back of the disk & face of the hub & try that, otherwise, if the disks are old, you will probably need to replace 'em (not too dear from Milners or Roughtrax)
hope this helps
ta
hawaii
