I own a 1994 L reg 3.0L surf and noticed a very small oil leak when i park up, it only seems to drip 4 or 5 times once it has been turned off. I keep checking the oil level and it seems o.k., so it must only be a very slight leak.
On inspection it seems to be coming from the rear of the block between the block and the gear box bell housing, there is also a piece of sponge between the block and bell housing that looks like it is made to measure, e.g. a manufactured part.
Any ideas about my small leak, is it normal to get small leaks on a surf this age, do i need to be alarmed and what is the sponge for and do other surfs have it.
Cheers for that, that's why all surf owners should be members of the forum.
