1KZTE Head bolts
  • 1KZTE Head bolts
    Hi,
    Can anyone confirm the correct torque settings for the cylinder head bolts, 3.0l 1KZTE engine ?
    Thanks.
    it is a bit of a grunt job have a reasonable length wrench & Use new bolts!
    working from centre of head outwards - alternate sides several passes
    to 39 Nm - 400 Kgf.cm - 29 Ft lbs
    mark heads of bolts
    tighten 90 degrees, same order as before
    tighten 90 degrees again same order as before
    check marks are 180 degrees from when marked
    No further tightening
    Tony
      Thanks,
      I thought that was right but 29LB-FT seems low.
      And I have 2 blue ones.
        not when you have to add 180 degrees!!!!!!!!
        Tony
