Is this a heated fuel filter? I have wires at the top of the filter but maybe these are to do with the sensor that tells me I have water in the filter... Can enyone tell me if it is a heated fuel filter?
It has a vacuum switch - that activates when diesel fuel viscous, usually when pretty cold.
So when fuel is struggling to go through filter, the vacuum switch would be triggered and heater would come on.
I have same filter and run on veg.
I fitted an over-ride manual button, and LED on dash to figure out whether its on or not.
I also have a thermostatic switch tied onto fuel cat.
The switch is a normally on type. and cuts off at 40 degC. So when coolant heats fuel cat to 40 deg, it cuts power to heated filter.
this happens in about 3 miles driving at this time of year
and 4-5 miles in winter.
I got LED's and switch from maplin
and mail ordered the thermoswitch from RS electronics
see here for my waffle and pics on subject:
http://www.hiluxsurf.co.uk/forums/sh...=heated+filterLandcruiser Colorado
Sub. Forester
Excellent Andy - thanks for that. Good link to your write up. Most of my journeys are <5 miles so I am going to run on a 50/50 mix and fuel line heaters won't really help if I go for a higher ratio of Veg oil. Nice to know that I have the heated filter if I get the mix wrong in winter..1996 3rd generation surf
I suppose you could still fit manual override switch. Before i fitted the themoswitch, i used to have the manual switch on for first 5-10 mins of journey.
however, you now know if mixture very visocous and thick, the heater will kick in anyway and help it flow through filter
but all this assumes vacuum switch in working order!
they can apparently be bench testedLandcruiser Colorado
Sub. Forester
