I have a Toyota hilux surf 3L TD Auto 1995 model. At idle the oil pressure reading is on the minimum mark and slightly higher when cruising yet while accelerating the needle on the gauge rises up but not above halfway on the gauge then settles down to the minimum mark... is this a common thing or problems with the oil pressure switch ? or is there a pressure release valve that would need replacing ?
I previously had a 1993 2.4l hilux surf and never noticed this happening on this models gauge.
ANY HELP WOULD BE GRATELY APPRECIATED PLEASE !
