water injection
    curious, and interesting... can we share a bit more information on this... Sounds like a fairly simple thing to install, with a reasonable gain. Which systems have people found/used...? which are better, easier... etc...
      Water injection
      It's certainly a lot simpler to fit than an intercooler, just a tank, a pump, a controller and a tapping into the pipe from the turbo to the engine.
      I fitted mine in an afternoon.
      Good power increase, lower air intake temperatures down from around 100'f to about 50'f immediately after a run. Cruising speed now up from around 140kph to around 145.Acceleration markedly improved.
      I was running 21.6mpg. Last tank 21.9. Not huge but I must try and remember the way I was driving before I fitted and slow down! (don't want any more points)
