which blinking engine have i got?
  • which blinking engine have i got?
    Hi, I know, a really stupid question.....but.........
    which engine have I got ? Is it a KZN130?
    I have a 4runner, 3.0 TD, N reg. How the heck do you know which engine is in it? All I want is a new back box, but I dont want to go ordering the wrong one. heeeeeeeeeeeelp !!!!!
    KZN is the engine code for a 3 litre. (LN is for a 2.4)
    130 denotes it's a Gen2
    (The Gen 3 is a 185)
    It just does, OK?
      so how do i know if its a gen 2 (130) or gen 3 (185) ?
        it should say on the vin plate under the bonnet
          Gen 2 has the fuel filler on the drivers side. Gen 3 on passengers!!
          It just does, OK?
            You've probably got a 1KZTE
            http://www.showmesome.info/hilux/inf...ne_numbers.htm
              Also
              3rd gens have a tailgate that lifts up (like an estate car)
              2nd gens have a tailgate that folds down (like a pick-up)
              On mine there is a black Toyota sticker on the top of the engine that gives the engine type - can't remember what mine says, sorry
              hope this helps
              hawaii
                Its a 1KZT
                If it´s a 4runner it is 1KZT not 1KZT-E wich is good because then you can add an intercooler and a larger exhaust without having to deal with an computer!
                Mine is the same.
                  Apart from all the other things mentioned...3rd Gens started around 1996 and also if its a 4 Runner it will be the UK Spec [ie no Rear Heater, A/C etc]...I believ these were stopped production around 1994/95
                  Gaz
                    You sure about that ?
                    Mines a KZN130, 1993, fuel filter definatly on the passengers side behind the air filter next to the NGR thingy...
                      FILTERS are all in the same place, its the FUEL FILLER CAP thats different
                      My 4x4
                      My choice
                      Back off
                        An N reg Runner will be a 95/96 and its a KZN130TD
                        (LN130 = 2.4 2nd Gen, KZN130 = 3.0 2nd Gen, KZN185 = 3.0 3rd Gen 96 on)
                        http://www.milneroffroad.com/KZN130.htm
                        My 4x4
                        My choice
                        Back off
                          Yup, only ever one deisel engine in UK 4Runners. 1KZ-T, and it will only ever be a 2nd gen 4 door.
                            Jeez.... I'm going blind..... I read that as Filter not Filler....
                            Time for a new monitor.... or glasses....
                              I did exactly the same, only I got a new monitor.
                              Does that mean I need glasses or sleep?
                              Back in the world of Surfdom
