hi all, went off roading last week got the rad full of s**t engine overheated to about 3 qtr not in the red also lost nearly all oil pressure it used to run about a qtr on tic over and about 3 qtr on running, got home and spent 3 days cleaning the s**t off n found out i had blown the turbo seals ( nice ) got turbo recond £586.00
having done a full oil n filter change and flush + rad flush, oil pressure is still low, ok on startup about half way but when she is warm still low also i get a slight ticking sound when idling
i have noticed that the oil filter is red hot is this normal not knowing how hot it was before the problem started
engine seams fine no lack of power n no smoke just low oil pressure n that dam ticking sound when been run for a while
im using castrol gtd 15w 40 before that 10w 40 with no problems
i have read past posts on oil pressure and it seams that that kind of pressure is ok but im still concerned cos it was better than that before my rather expensive off road day.
i have had the rocker cover off and its clean as a whistle no sludge im contemplating taking the oil pan off but it sound alot of hassel.
please please please any ideas
many thanks a troubled surfer
