coolant/autotransmission oil
  • coolant/autotransmission oil
    Hi folks just changed my antifreeze, after flushing by refilling with cold water and draining the rad twice after getting engine upto temp. i have found that i could only get 5.5 litres of comma red antifreeze in the radiator! Also according to the manual the auto g,box capacity is 2 litres, mine drained out 4.2 litres! so thats what i put back in. the level is correct upto the hot mark (with a hot engine) after engaging all gears then switching of the engine.
    Have i anything to worry about I assume the engine did not drain completely of coolant but why double the amount of gbox oil?
    did you have your heaters set to hot? also try a search on burping the system...
    it's in me shed, mate.
      Thats all about right, unless you drain the block you'll not get all the coolant out.
      And the gearbox is OK, 4-5 liters is the usual amount that drains out, your manual must be hung over!
