what is the highest speed you can do and change into 4WD from 2WD also is there a speed limit when in 4WD cheers ..............andy
4wd
Here's how...
How do I operate the different Manual Transmission options?
To shift from H2 to H4, reduce your speed to less than 80kmh/50mph and (for UK models) move the front drive control lever or (for other models) press the 4WD button. No need to depress the clutch. If you have trouble shifting in cold weather, reduce your speed or stop the vehicle and reshift. The 4WD indicator light may not come on even if you shift into H4 if the vehicle is stopped, when you start to move the vehicle will turn it on.
To shift from H4 to H2, simply (for UK models) move the front drive contol lever or (for other models) press the 4WD button. The vehicle may be moving at any speed. No need to depress the clutch.
To shift from H4 to L4, stop the vehicle or reduce speed to less than 8kmh/5mph. With your foot off the accelorator pedal, depress the clutch pedal and move the front drive control lever.
To shift from L4 to H4, depress the clutch pedal and move the front drive control lever. The vehicle may be moving at any speed.
CAUTION:
Never move the front drive lever if the wheels are slipping. Stop the slipping or spinning before shifting.
