Guys,
can't find the engine mount torque settings in the 1KZ-TE engine manual that’s floating around. Anyone know what they are?
Also I think I'm getting too much engine movement. I can see the transmission housing move a lot too especially when you rev the engine. I am wondering if the excessive engine movement is also causing a squealing noise (like escaping hi pressure) when accelerating.
How much movement should you see? Where do you measure that?
