My Hilux Surf
  • My Hilux Surf
    Hi, What Would Cause My Diesel Engine To Hard Start When Hot? My Engine Model Is 1kz-te 2982cc, Kzn185-0012755. Should I Check For Lost Of Compresion Or Could It Be The Injector Pump Not Pumping Fuel When Hot?
    Thanks For Any Advice You May Have On This.
    Hi Jeffrey,
    It could be..................
    A blocked air filter,
    Air in the fuel lines,
    Fuel pump timing,
    fuel pump malfunction.
      Hi Jeffrey,
      Fuel pump timing,
      Also seized / sticky turbo
        also you didnt have in [P] Park if its an auto.
