Hi All, Back again!
rebuild going well however, on having my rad checked as the core was a bit suspect the rebuilder has found that the trans oil cooler in the bottom tank is leaking - in my rad a s/steel? plate type. does anyone have any ideas? he came up with a tube within tube type that was in a turbo d L##d R###r (sorry all for the bad language!) and says that he can fit it into a new fabricated bottom tank that will need to be 20mm deeper (any potencial problems there?) or to concider a separate air cooled job, if so any ideas where to put it, what the rating should be etc. hopefully some of you off roadies have had to cool your boxes!!!!
Tony
Tony
