Hi Tony
Your email isn't working via your website so I am hoping that you get to read this.
I see that you are now in the servicing business, and as I am only down the road in Bristol I was wondering if you could give me a quote for a few jobs:
1996 3.0 Surf
Change the cam belt (I have a genuine Toyota one).
Change the ATF fluid.
Flush and refill the coolant.
Fit an ATF rad.
Supply and Fit Uprated rear springs.
Check and adjust valves (possibly).
Check and top up diff fluid.
Give it a check over.
All of the other belts and filters have been changed.
Many thanks
Rob G
rob@hitenter.co.uk
www.hitenter.co.uk
1996 3.0 Surf
Fit an ATF rad.
Many thanks
Rob G
rob@hitenter.co.uk
www.hitenter.co.uk
