So my 1st gen runs a 3.0 diesel 1KZ/T (which was taken from a 2nd gen UK 4runner)
The fuel stop solenoid went, and it took a lot of Googling to find correct part numbers. So I'm listing them here for reference in case anybody needs them in future
Mechanical fuel pump
The mechanical fuel pump number is 22100-67040 (alternative number might be 096000-8850)
The 22100-67040 is a number given to me by Toyota
It’s also on the actual fuel pump itself (see actual pic below)
Fuel stop solenoid
This is like a spill control valve on the EFI fuel pumps
When you turn the ignition off, the plunger comes down to block the fuel so the truck stops
It takes 12v power when ignition is on to pull a plunger out of the way so fuel can flow
Part numbers
- 096030-0160 was the one given to me by UK Diesel Parts based on the fuel pump number - https://www.ukdieselparts.com/
- It appears it’s pretty generic and used in tons of Toyotas and may have about a million different part numbers
- The other ref I’ve found is 22390 6a511 (maybe also 096030-0520). This is on Milner Off Road and lots of other websites
Hope that helps anyone who is Googling for the answer and stumbles upon this page
Fuel stop solenoid
Part numbers
