Hi gents, just a quick one do i check the transmission fluid level with the engine running or not, cheers in advance.
transmission fluid
Hi John,
First take ya Truck for a run round the block to warm it up (always check it when HOT) before switching ya Truck off run through the gears, turn it off n continue to check fluid level
Good Luck
17+ Years of Surfs n 9 years on Spotless it ain't but Faultless to a "T" is my KZN 130 Yota !!Buncefield Burner
Pull the OD fault codes. Use a paper clip to short E1 and TE1 in your diagnostic port in the engine bay. Then turn the key and , as dash lights come on, count the times the OD light flashes. Then post on here. Late shifting and loss of gears is often the autobox solenoids. Cheers
