Hi, been wandering in the shadows of this forum for 6+ years and never had to post anything due to the wealth of information on here. im sure someone has posted
Power steering reservoir has what looks like engine oil in it????
atf as said before, best way to change it i found is to use a vacuum pump to suck out the old fluid.
remove one pipe from reservoir, and find a pipe to replace this to block so the reservoir does not leak, fill with new fluid and draw the new fluid through and keep topping up the reservoir, keep doing this
