not driving
  • not driving
    We were cleaning the car with the radio in and accidently pushed the nasty little red button. Now the engine sounds lovely, the gears change but drive does not happen in any dirrection even with a bit of gas. Something appears blown as only part of the dash board lights come on. Any suggestions?? What could be blown?
    You mean the button in front of the auto shifter? All that does is let you move the lever without the keys in.
    You've not knocked the 4wd lever into neutral?
    Under the radio, on the floor is the 4wd ECU, check the wires arn't loose going in to it.
      Thankyou
      Thankyou so much. We had knocked the 4wd into neutral. You saved our weekend!!!! You are a star.
