Hi, all you out there.
I have a 1993 3.0TD which is ace, apart from an annoying electrical problem.
The speedo is eratic. It can jump up to 35mph when turning the ignition on (at standstill). It can register zero when traveling. It can fluctuate between zero and whatever speed I am traveling at.
This affects the automatic transmission, which in turn affects fuel economy.
The worse occasion was when traveling down a dual carriage-way, the speedo only registered 30mph. This then didn't allow the auto. transmission to shift up and I was revving at 3500rpm, moving slowly and burning fuel like there was no tomorrow! This problem is also intermittent.
I have consulted a local auto. electrician who said he needed wiring diagramms, some of which I have found on the net, but none show the link between the speed sensor (instrument cluster) and the auto. box.
Any help would be greatly appreciated.
Nil Illigitimi Carborundum
