Ok have a spooky recurring problem. I have Very soft coolant hoses.
I have no or little pressure in the coolant system, after a 20 mile run I could remove the rad cap with engine still running with no overflow. Could see coolant in rad cap. No leaks visible, no smoke at the rear, expansion tank a bit fuller than usual but not radical. Soft hoses, and heaters working fine.
Recently changed rad but this problem has been on going on old rad and new one(recon).
Had new head fitted 6 months ago and new water pump two months ago.
Any ideas as this is baffling me?
thanks
Ronnie
thanks
Ronnie
