I Have Heard There Is An Adjustment Somewhere On The Diesel Pump Where You Can Alter The Amount Of Fuel It Delivers.my Surf Is Smoking Like A Chimney,just Had Injectors Refurbed,timing Belt Done,filters.does Anyone Know Where This Adjustment Is.(im Not Talking About Pump Position Adjuster,this Is Some Kind Of Screw I Immagine)
Diesel Pump
Not on the 2LT-E pump.Fuel supply is controlled by the ECU.Originally posted by freemanI Have Heard There Is An Adjustment Somewhere On The Diesel Pump Where You Can Alter The Amount Of Fuel It Delivers.my Surf Is Smoking Like A Chimney,just Had Injectors Refurbed,timing Belt Done,filters.does Anyone Know Where This Adjustment Is.(im Not Talking About Pump Position Adjuster,this Is Some Kind Of Screw I Immagine)
Neville
