Starting probs
  • Starting probs
    Hi all,
    My mates surf starts 99 times out of 100 perfectly, cold or hot
    The other 1 time (can be any time hot or cold) it turns over & over & will not start
    It never cuts out when running so i assume that eliminates an electrical problem to the fuel cut off valve in the pump ?
    Anybody got any ideas ?
    Originally posted by SSXsupra
    Hi all,
    If it's an automatic, could be loose connection on starter inhibitor switch (maybe).
      Try turning the ignition off and on a couple of times, it works for me.
      Cheers Ron.
