Hi
Posted a question about a noise from the front steering after using 4WD on hard dry ground. The main reply back was to get under it and grease all the points on the drive.
I have done that now but the noise is still there...
It happens when you put it into 4WD and then turn either past half lock.
It sounds like a metal bar being dragged along spaced metal railings but under tension?
any thoughts
Thanks
Mark
any thoughts
Thanks
Mark
