A open ended title but specifically I'm trying to find a labelled drawing or schematic which shows the layout of 91 2.4td so that I can check things like fuel/oil/air filter etc
where's everything??
short & sweet
Hi Tasadin
Bonnet up air filter right hand side front,fule right hand side
on the bulk head,oil filter left hand side of the block to gain
acess to oil filter off side (drivers)wheel arch.
Enjoy
Chris
Complete kit from Milner off road about £13 + vat
GOT NO COWBOYS HERE?
The only one you can check is the air filter and its in the big black biscuit tin on the RHS of the engine bay.Originally posted by TasadinA open ended title but specifically I'm trying to find a labelled drawing or schematic which shows the layout of 91 2.4td so that I can check things like fuel/oil/air filter etc
The other two you will find when you've bought new ones and can compare. Its easy as falling off a log but then theres always the rapids....
