I am rebuilding an engine. I took out the pistons and all four are cracked between the top two rings!! That explains the smoke and power loss anyway. What pistons can I fit into the engine? I have three good ones from an old pickup 2L engine, and could get another for a set. There are sets on ebay for relatively cheap for KZN engines. I have had a look on Toyo-DIY and there is a lot of cross referencing of part numbers, it seems this piston is used in lots of different engines. What pistons can I actually put in a 2.4 surf??
I have had the head skimmed too, not by much at all, so the compression will not have changed dramatically. I do want to get a thicker gasket than standard. Where can I get a thicker gasket?
cheers
cheers
