Just driving along, eng cut out. Now will not start HELP ?
Help just stoped
Had you just filled up with fuel?
When it turns does it sound like it is about to start or does it barely turn over?
Are you waiting for the glow plug sequence to finish?
(If you open the bonnet and get a helper to turn the ignition on you will hear or should hear a click from the glow plug relay.Eat.Sleep.Surf.Repeat.
Fuel in for three days. Turns over as it always has, just not starting. I have a buzzer when glow plugs have heated and amp meter reading near 50 amp when heating.Relay coming on / off. thanks for help we will keep on trying. When it stoped it was just as i had turned the key off, just stoped.
