Hi All,
I know there are numerous threads on burping surfs cooling systems but I think I have tried the majority of the suggested methods.
I have a 2.4 diesel 2l hilux LN85. I changed the thermostat (new one 88oC) cause it was stuck open. I also changed the coolant well I was there. (Im running radiator off a 5l)
I filled it up with new coolant through the radiator cap on top of the radiator and pulled off the outlet from the heater to ensure no airlocks in the heater. I drove it round the block until it heated up to normal then come home and took the radiator cap off and topped up with coolant.
I have two problems,
1) the bottom radiator hose is still cold after all this
2) it seems as if the themostat is not releasing probably cause of the airlock (i tested that it opened in boiling water)
I left it running at 2000rpm in the garage for about 20min with radiator cap off and still no themostat release.
This is really ####ing me off as a simple task has turned into a real prick, do any of you guys have any suggestions ???
