2,4TD
Just searched on "Timing Belt" and "Cambelt" to get an idea of the job. Hear it is rated as a 2.5hr job at a garage but it *looks* worse than that.
But am I right to summarise that with a good toolkit and determination everything will come off without special tools or disaster? Best to take out radiator for better access, and a good chance to properly flush it....yes? Also seems that air-con can be moved aside enough without undoing pipes.
Are there any tensioners that need changing? Tensioner cost?
This vehicle has covered 76K and we understand was imported a few months ago at about 73K. The timing belt light goes out so might you think it was changed in Japan before it came here. Are they good at doing that to schedule over there...even when they know it is about to be exported?
Do you think there is much of a scam just resetting the light and not doing the belt??
Thanks,
David
Thanks,
David
I,LL GO FIRST NO PROB
