Cam belt
  • Cam belt
    Hi all, just got a new cam belt today,(gates)the part number is 5214XS, it says on the box it fits 4runner(ln) 2.4TD, would this be the same as a ln130 surf. Man at the auto part place said it was the only one listed. Many thanks Mick.
    Id say yes.
    Сви можемо
      Ok that's great, thanks for that.
        Hi mate,
        Don't forget to change the tensioner and spring
        and idler pulley at the same time, also the water
        pump, could save doing at all again.
        Gman.
        If it aint broke, keep goin' till it is.
          Good point, was only going to do the belt because changing fuel pump, but as you say might as well do it all as it will be stripped down. Many thanks Mick.
