New glow plugs, barely starts now.
    I've tried it with both my old glow plugs and the new ngk plugs. they seem to be about the same for starting, the resistance tests good on all of them. I agree it does sound like a glow plug problem but ive tested everything and there should be no reason for them not to work. if it stands for 5 or 6 hours I can try to crank it without the plugs and it doesn't fire. one cycle of the plugs and it jumps right to life. I am running rotella 15w40, always have, with a wix filter, oil was changed a week before my problem showed up.
      Does seem a bit weird
      Does it start ok when you have your pan heater plugged in over night?
      Eat.Sleep.Surf.Repeat.
        Yeah, as I mentioned I had it plugged in last night (I only have an inline coolant heater) it was fairly cold this morning, about -20 and one cycle of the glow plugs (until the beep) it fired right up. I had it unplugged from friday to sunday, it was about +2 on sunday and it wouldn't start like it should. fuel had stayed primed, I checked the primer before I tried to start it and it was hard.
          I am tempted to think that the relative thickness of your engine oil may not be helping the situation.
            I have my new engine temp sensor and should have my intake air temp sensor tomorrow. I will install those and go from there.
              Installed both sensors, no real change. Been running the old glow plugs and they were starting a little rough and not really liking cold weather. Threw the new glow plugs back in yesterday and it's really having a hard time starting again. I don't get it, these are the new, proper plugs and they're worse than the old ones. Going to dig into possible timing issues when I have some time away from work. I can't think of much else anymore
