starting problem
  • starting problem
    recently had a wire fire above starter and burnt wire harness ,, after rejoining 27 wires ...all correctly i hoped that would be it but no ,there is no heater light on now and it wont start, it turns over but wont fire up ,,.. is there anything else that may of burnt out,?? (all fuses are ok) ???
    Pop what you're driving in your profile. It'll show up under your username and will help peeps' diagnosis
      ok thanks have done
