Fuel Return pipe
  • Fuel Return pipe
    Howdy guys, I've got hte 2.4 93 Hilux Surf, need to use some of that liqui moly stuff to clean out the engine, and just asking if anyone can specify the fuel return pipe, as I just want to make sure I get the right pipe before I do this
    On mine it was tge smaller diameter pipe
      hose
      Tge? Sorry bad with the terminology, is the same pipe that runs with the pipe from the filter but ignores the filter going into the firewall
        No termonology there. Combination of idiocy, dyslexia and an iphone
          I've got bad luck
          Well all done now, I think I made a mistake resetting the ecu since i had reconditioned injectors cus now my turbo isnt working after the ecu reset, was perfect before it now no turbo light
            Fixed
            simple mistake, just had to plug the vacuum pipe in again
              It's pressure not vacuum if you mean the one to the Turbo Pressure Sensor.
              Nev.
