hi all just bought my first surf a 1991 2.4 ssr auto . it is brilliant much better than the disco i p/xd. i want to tow with it is an oil cooler standard ? there are 2 pipes coming out right side of g/box is that it ? cheers
oil cooler
Hi and welcome to this wonderful but slightly mad place on the webOriginally posted by snowyhi all just bought my first surf a 1991 2.4 ssr auto . it is brilliant much better than the disco i p/xd. i want to tow with it is an oil cooler standard ? there are 2 pipes coming out right side of g/box is that it ? cheers
The oil cooler is built into the rad some have fitted extra oil coolers and some haven't the choice is yours. ENJOYI'm a custard donut monster
welcome Snowy, I too part exed a D---o for the Surf and I have not stopped grinning yet, I have been towing caravans since 1975 with several towcars in that time some manual some auto. I can say that there is nothing like heat to kill an auto gearbox and the standard cooler fitted as part of the rad is not man enough to dissapate the extra heat produced by towing. As a matter of couse I have always fitted an additional oil cooler. Kenlow do one for the Surf around £100 and it is DIY fitting.Visit all the Surfin Elkhounds at [url="http://www.malenibo.co.uk/"]www.malenibo.co.uk[/url]
You will find that the pipes coming out of your gearbox go to an oil cooler fitted inside the bottom tank of your radiator. In Oz it has been found to be very inneficient. I myself had the bottom tank replaced with a standard tank out of a manual Hilux (no oil cooler) and I fitted a seperate oil cooler in front of my radiator. I have done many Klms towing a boat and have had no overheating problems.Originally posted by snowyhi all just bought my first surf a 1991 2.4 ssr auto . it is brilliant much better than the disco i p/xd. i want to tow with it is an oil cooler standard ? there are 2 pipes coming out right side of g/box is that it ? cheers
FrankW
[QUOTE=FrankW]You will find that the pipes coming out of your gearbox go to an oil cooler fitted inside the bottom tank of your radiator. In Oz it has been found to be very inneficient. I myself had the bottom tank replaced with a standard tank out of a manual Hilux (no oil cooler) and I fitted a seperate oil cooler in front of my radiator. I have done many Klms towing a boat and have had no overheating problems.
WOT ARE THEY LIKE TO FIT DO YOU HAVE A DIAGRAM TO DO THE JOB AND DOSE THE HOSES FIT STRAIGHT ON TO THE ONE AT KEN LOWE.S
