soot in engine bay turbo??
  • soot in engine bay turbo??
    i seem to have a lot of soot in my engine bay possibly coming from my turbo any ideas?
    Check your exhaust joints
    Eat.Sleep.Surf.Repeat.
      as in where turbo joins to exhaust manifold?
        Probably where the turbo outlet joins onto the exhaust downpipe.
        Have a feel around the joint to see if you can feel the gases, probably best with a cold engine.
          Saw something similar just recently. If it's over everything which looks to be the case to me, then check it's not belt dust. Worn belts will produce a lot of dust.
          Nev
            its defently when the engine is reving, but im also having turbo issues (generally not working) was thinking of buying one of these http://www.ebay.co.uk/itm/1408257586...84.m1423.l2649
            would it be any good for my 2.4 2nd gen
              that soot is all over the engine. either its road grime or you have a cracked manifold. normally it would be roaring like crazy.
              if its struggling to get boost then a cracked manifold or blown exhaust gasket is highly likely.
