good morning guys,
i have a slight problem that you may be able to shed some light on,
The story,
brake pedal was goin down to the floor when parked at lights, and losing brake fluid (quick search on here) and it was exactly what you guys said, "brake line over the fuel tank leaking"
took it to the garage, very gingerly as hardly had any brakes!!
all fixed no worries £130.00 new brake lines fitted/bled sorted,
The problem now,
since coming back from the garage the truck has developed a vibrating? noise when it gets between 15 to 25 mph ? the noise sounds like when you have got a manual car in the wrong gear, ie doin 25mph in 5 gear? if that makes sense??
tick over when parked is ok, and all other speeds are ok, its just when it reaches about 20mph ?
the garage, dropped the tank, and the prop, to change the brake lines,
i suspect it has some thing to do with the prop ? (but they did say they put some chalk on it to line it back up)
any ideas would be greatly appreciated
thank you
craig
The story,
The problem now,
thank you
craig
