How often do you change your fuel filter when running on SVO, WVO & bio diesel?
Fuel Filter Replacement Running On SWV, WVO & BIO Diesel - How Often?
If you are running on bio, and it is of good quality, the first couple of changes are done fairly regularly (like, check it often), but after all the old dino-diesel crud is shifted off the pipes and the tank walls, you will find that filter changes are needed only as often as those from any other car. But you must monitor the quality of fuel you are using - make it yourself preferably.
Is that twice as often as in if the filter was not changed regularly, or twice as often if it was?Originally posted by BUSHWHACKER View PostTwice as often.
I leave my filter longer than the recommended change interval, because it is not necessary to change as often as that, because of quality fuel.
Nev
