So I'm trying to do as much preventative maintenance as I can on my surf. A little background on the vehicle. I bought it last fall with 199,980km on it. Had a bad oil leak and the passenger side was beat up quite bad from a previous owner rolling it. There was also a metal on metal noise when cutting the wheel hard.
Got it home, the speedometer rolled over 200k indicating timing belt had to be replaced, so I got a new belt, tensioner, and crank and cam shaft seals. Installed them all which in turn stopped the oil leak. Kept hearing the noise when cutting hard and the last straw was when my steering wheel kicked out of alignment (truck only has about 200,500km at this point). I dropped it off as a shop and the mechanic had it for 3 months and took me for $1700 (replaced steer column, upper pitman arm and lower control arm) and the problem still persisted when making sharp right turns.
So that's my little history. Since April I've put 25,000km on it, religiously doing oil changes every 5000km with high quality synthetic oil.
Alignment issues
I noticed wear on my front tires so I went to get an alignment. Before doing so I replaced my inner and outer tie rods and sleeves. After the alignment I was told it couldn't be done perfect because they ran out of toe in (it's months later and I still have no idea what this means even after asking several people). Any ideas?
Overheating issues
I bought a home made 5 x 8 cargo trailer to haul my belongings with me (total weight with my stuff is probably around 1500lbs or less... I'm guessing way less). Made a few trips to BC through the mountains and on the third trip I started to have overheating issues that got so bad that I can't even haul my trailer at all now unless it's on completely flat ground. My engine will get so hot that it starts spitting all the transmission fluid out the vent in the top. I've since started to get heating issues on large hills whereas I never did prior to hauling the trailer. It was recommended that I have a larger exhaust installed (2.5") and for me to not haul a trailer anymore. I've also ordered a K&N air filter in hopes of increasing the air flow to the engine and am toying with the idea of an intercooler, but I'm stumped as to why it keeps heating up now whereas it didn't originally. Also thinking of getting a thermostat that kicks the fan in at a lower temperature. I have also purchased another used clutch fan just in case. Any other suggestions?
Preventative Maintenance
I have ordered/am ordering and plan to install the following parts:
Upper and Lower Balljoints
Rear coil springs
Rear Heavy Duty Shocks
Air bag suspension for inside coils
Clutch Fan
Low Temp Thermostat
2.5" exhaust system (will be made and installed at a shop)
New tires (in a couple more months)
Replace transmission oil and clean filter
Fuel filter (will be done tomorrow probably, still trying to find an original filter housing seeing as when I bought the Surf all it had was one of the clear plastic ones)
New front seats if I can track down some Recaro ones like I have. I found some in Japan, but they're $500 a piece and I'm not quite sure if I want to dump that much into just seats. My driver seat is pretty shot though. The rubber on the bottom holding it up has ripped so I just have some old clothes stuffed under to hold it up. And the foam has collapsed on one side as well.
Anyone think of anything I may have missed? I love my Surf and just really want it to last.
Alignment issues
Overheating issues
Rear coil springs
Clutch Fan
Low Temp Thermostat
