Hey all,
Just when I thought I'd fixed the Black Beast, I get a phone call from my mum in France saying the truck's overheated again. Last time, we traced it to the water pump leaking, which after a record amount of swearing I replaced and sealed properly.
I've been keeping an eye on the engine, and despite being pushed occasionally the machine stayed cool, so I thought the cooling system was sound, but it seems there's a leak somewhere. I've been seeing moisture with a green tinge (i.e. coolant) on the side of the engine underneath the fuel injectors. The entire engine block has been covered in this moisture every time I look, so I can't see where it could be leaking from. Yeah, this sounds like poor maintenance on my part, which it could well be, but we gave the truck to a mechanic to look for the leak and he couldn't find anything out of line - all hoses etc fine and sealed.
Given this, how would I go about tracing this troublesome leak? It seems to be a tiny one, only opening up when the engine's hot and the cooling system's under pressure, i.e. a long motorway drive. And naturally, at that speed I'm guessing the leaking coolant is being plastered all over the engine block. I can fully appreciate coolant being coloured to say 'this ain't water here, you've got a leak!' but at the moment, all it's saying is 'on the passenger side of the engine.' I don't know a lot about the 2L-TE, but the only cooling system component I'm aware of on this side is the filler/distributor, and that got a clean bill of health from the mechanic. Any ideas where I could start?
Sorry to ask for so much help for this machine, I really am, but I'm starting to feel out of my depth with this car![Frown](https://hiluxsurf.co.uk/core/images/smilies/frown.png)
Cheers,
Gargravarr
Edit: should also add that I put Radweld into the system before we twigged it was the water pump, so that appears to have done zilch.
Cheers,
Gargravarr
