When should the turbo kick in on a 2LTE? mine seems to kick in around 2200rpm which seems a bit late, if it is late does anyone know how to make it come in sooner??
When should turbo kick in on a 2LTE???
I dunno for certain, but it sounds about right....mines come in approximately around 2300-2500...not really concentrated on it kicking in...as long as it does!Originally posted by MuzWhen should the turbo kick in on a 2LTE? mine seems to kick in around 2200rpm which seems a bit late, if it is late does anyone know how to make it come in sooner??Gaz
Mine comes in between 1600 rpm and 2200 rpm depending on throttle position and engine load (earlier when going up a hill).Originally posted by GizmoI dunno for certain, but it sounds about right....mines come in approximately around 2300-2500...not really concentrated on it kicking in...as long as it does!
The green light comes on mine at about 2000rpm and then its on when ever i'm on throttle,although i can here it wind up below 2000rpm even though green light is not on,if that makes sense.Originally posted by MuzWhen should the turbo kick in on a 2LTE? mine seems to kick in around 2200rpm which seems a bit late, if it is late does anyone know how to make it come in sooner??
Mine (and the green light) kicks in at 1800rpm but also hear it spooling sooner,this is also dependant on throttle position and manifold vacume but
Im with Gizmo "as long as it does!" around this figure I wouldnt worry.Before you can pass judgment on someone first you must walk a mile in their shoes, And when your a mile away......YOU HAVE THEIR SHOES!.
