Hi Guys,
I bought a '93 LN130 2.4TD surf approx 6 months ago.
When i got it first it would only start after 2 attempts and there was a bit of smoke when starting from cold.
We advanced the diesel pump and this prob was somewhat rectified, it's still a bit smokey when starting from cold.
There was a wobble in the steering when driving over about 80kph.
Tightening the wheel bearings completely solved this problem.
Anyways, we have done a few bits and bobs to get her running a bit smoother.
Last Friday i was approx 1km from work when i noticed the gears were not changin correctly. Within 1 km there was no gear changing at all... i pulled her in and looked underneath to see all the gear oil had drained out on to the ground and it looked to be coming from up near the rad/cooler.
I've ordered a new rad but it won't be until this evening that i will be able to have a good look to see where the prob is exactly.
It needed a new rad so i'm hoping that that is the problem!
Failing that i'm hoping that it is just that one of the pipes going from the transmission cooler back has burst.
I will let ye know how i get on after this evening and will hopefully have some more definitive descriptions of the problem.
Any advice appreciated!
