View Post
Fan at start-up
Stick "M16x1.5 switch" in an EBay search - you'll find half a dozen that will do the job for £10 or less. Temperature of operation may differ by a degree or two and you may have to cut the plug off and wire direct - but no real difficulty. Saves a few quid.
I got one of eblag a while back
http://www.ebay.co.uk/itm/3102784519...ht_1728wt_1396
that is for a 90 85 they do one for 97 92 as well
Simples to fit one spanner sorted Obviously do it when the engine is cold.Last edited by shokenore; 5 January 2012, 22:47.Eat.Sleep.Surf.Repeat.
Intermotor Part no. 50380
http://cgi.ebay.co.uk/RADIATOR-FAN-S...ht_4358wt_1163
You will have to cut off the original plug and fit a crimped female spade .
Or shell out for the £70 original
The fan switch is normally closed.
If you were to short the connector against the block the fan should not start.
The fan fuse is in the fuse box near to the battery (drivers side).Eat.Sleep.Surf.Repeat.
