Hi yet another question
. The water level keeps going down in the bit with the radiator cap top. The cylinder head aparently has been done by previous owner and the garage I took it too said that it looks like its been apart I've had the garage take a look a few times and they cant find the leak. The engine doesn't seem to be overheating as the temperature gauge needle sits in the middle and doesn't go any higher. It starts first flick of the key with no clouds of smoke/steam and runs well. The only answer the garage has come up with is there could be a crack in the cylinder head but the cooling system isn't pressurising. Its really puzzling. Does anyone know if there is a common problem with water loss from anywhere.
Many Thanks Tom
. The water level keeps going down in the bit with the radiator cap top. The cylinder head aparently has been done by previous owner and the garage I took it too said that it looks like its been apart I've had the garage take a look a few times and they cant find the leak. The engine doesn't seem to be overheating as the temperature gauge needle sits in the middle and doesn't go any higher. It starts first flick of the key with no clouds of smoke/steam and runs well. The only answer the garage has come up with is there could be a crack in the cylinder head but the cooling system isn't pressurising. Its really puzzling. Does anyone know if there is a common problem with water loss from anywhere.Many Thanks Tom
AFTER MARKET TEMP GAUGE NOW
