how do you remover the crankshaft seal cant get the pulley off its an ln130
oil leak
You need to make something to hold the pulley while undoing the centre bolt, then use a puller but not the type that holds onto the outer lip of the pulley. I used a slide hammer that bolts to the centre but i did have the bumper and radiator removed.
DazzaNon consternationes.
pully is off all whats left is key on crank thats what iam trying to get offOriginally posted by dazandcaz View PostYou need to make something to hold the pulley while undoing the centre bolt, then use a puller but not the type that holds onto the outer lip of the pulley. I used a slide hammer that bolts to the centre but i did have the bumper and radiator removed.
Dazza
http://www.hiluxsurf.co.uk/showthread.php?t=43061
Post 9, i think this is where you're upto.
Where abouts in this fine county are you?Non consternationes.
should pop out
