Hopefully one of the adults will read this?
After eliminating any oil leaks from the breather pipe,are there any other common oil leak areas to look for....it is more Torey Canyon than Amoco Cadiz well ok slight exaggeration more of a small weep but it is quite annoying not enough to require top ups between oil changes but enough to stain the drive should I spend hours looking and trying to fix it or buy a bag of cement?
