idler arm brace
  • idler arm brace
    Do any of you guys know someone that makes them? There easy to find for the LHD models over here but can't find anyone that makes one for the surf
    Never seen one, I doubt you'd really need one unless you're running hydraulic steering assist. Only replaced the bushes once in 4 years running 33's on mine.
    Try some Aussie sites, they are RHD and get a little more serious offroad than in the UK.
    Probably have to make one yourself if not. The Downey LHD one looks reasonably easy if you can weld and cut metal. Have you actually managed to bend one yet?
      I haven't bent it yet but with the lift it taps the chassis at full flex so I'm sure it's only a matter of time. Thanks TonyN
        There have been a couple made down here.
        None commercially available that I know of. Maybe some others on the Aussie Forum have some info.
        http://www.toyotasurf.asn.au/forum/v...dler+arm+brace
