amount of oils/? 2.4 t/d ln130/ 92 ssrx
  • amount of oils/? 2.4 t/d ln130/ 92 ssrx
    hi peeps, have drained rear diff/ oil was brown reddish.
    front diff was, light brown and a burnt smell to it.
    how much goes in to the rear diff, and how much in to the front diff.
    is ep 90 ok to replace/ advise on / and make of required oil replacement.
    how often should this be done.
    thanks ozzy.
    uses about 2 lites in each... just fill till you can't get any more in.
    i think i used 95 last time
      Check out the first sticky in 'Technical-Mechanical-General'
      All the volumes and oil types to go back in and when to change are here
      Look out! Ee
