I have just done a routine change of glow plugs and fitted the correct type with no problem and checked after to make sure the 12 v to buz bar was all good, I checked the fuse and thats good but it now turns over and over for ages to get it going soon as I did the glows plugs? It was fine before!
I checked the air vacuum off the efi air box, made sure all clips are tight and I have no idea now why changing the plugs can make the vehicle not start fast...I even drilled a hole in diesel cap!
desperate
desperate
